Start Up problem
JEFFREYRED
  • 2000 GMC SONOMA
  • V6
  • FWD
  • 53,000 MILES
This has been a persistent problem for probably about a month or so, when I go to start it up sometimes it clicks turning over before it starts, and then other times when I am starting it it will seem like its going to take time to start up and then it starts up aggressively quickly. Also occasionally it will shut off, It is happened about three times where it will not start up at all. Any suggestions, or help?
Wednesday, August 30th, 2017 AT 8:29 AM
HARRY P
  • 2,292 POSTS
That is probably a battery terminal/cable issue. I would replace the terminals and clean them with a wire brush. Side mount battery terminals are junk, frankly. Whenever there is a power issue, I replace mine because they only cost a couple of bucks and are usually the problem. You might also take the cables off at the starter and clean them up too.
How to clean the battery cables: https://www.2carpros.com/articles/everything-goes-dead-when-engine-is-cranked
If that does not solve the problem, then you should probe the starter when it is in its clicking mood. Using a multi-meter, you will ground the black multi-meter lead and hook the red up to the red trigger lead going in to the starter, and then check to see if twelve volts are getting to the starter when someone turns the key. If there are twelve volts, then pull the starter and have it tested at the local auto parts store (they will do it for free).
Information about starters and how they work: https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
Start simple with checking the cables and go from there. Let us know how it goes for you.
Wednesday, August 30th, 2017 AT 8:56 AM
JEFFREYRED
Thank you I definitely will!
Wednesday, August 30th, 2017 AT 9:30 AM
