Stalls, wont restart
THREEFLOWS
  • 2001 CHEVROLET TAHOE
  • 5.6L
  • V8
  • 4WD
  • 133,450 MILES
After sitting for many months, the engine will start, run for a few minutes, then stall. I have replaced the fuel filter and verified that the fuel pump is running. I added de-watering fluid to ensure that the gas is good. I have verified my coil packs and spark plugs, and again, the engine will start, and run for a few minutes. I have replace the ignition switch housing to replace the passlock sensor. I have gone through several iddirations of the thirty minute relearn procedure without success. Internet videos do not lead me any further. What should be my next step?
Tuesday, October 11th, 2016 AT 12:16 PM
WRENCHTECH
  • 20,761 POSTS
You need to do your testing during that period that it is not restarting.
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can only be tested during the failure. Any other time and they will simply test good because the problem is not present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That is what we have to look for.
These are the basics that need to be tested and will give us the information required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the positive terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
4) If all of these things check good, then you would need to do a complete compression test.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Tuesday, October 11th, 2016 AT 12:21 PM
