Stalls under load
268,500 MILES • 2.3L • 4 CYL • 2WD • MANUAL
JW1983
The engine tries to stall under a load, idling fine, noticed when motor is cold and hot.
Oct 26, 2018 at 7:31 AM
Good evening.
Does the engine actually turn off or just will not pick up speed?
Possible issues could be low fuel pressure or a clogged catalytic converter.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Oct 26, 2018 at 8:12 AM
JW1983
If I do not press the clutch to release the load it will choke down. I have had two other vehicles with similar symptoms and it was the torque converter switch. I was beginning to think it could be the catalytic converter or TCC. My diagnostic has a short or loose wire so cannot get an OBD reading.
Oct 28, 2018 at 4:45 AM
Okay, first, if you have a standard transmission which is what you indicate, there is no torque converter.
The catalytic converter should be checked for back pressure. You can rent a gauge at a parts store and install it where the O2 sensor is at the exhaust manifold. Anything more than 1 lb indicates a clogged catalytic converter.
Oct 28, 2018 at 5:11 AM
JW1983
I will give that a try.
Oct 28, 2018 at 7:07 PM
Keep us updated.
Always glad to help.
Oct 28, 2018 at 7:10 PM
