2003 Ford Ranger Engine Stalls
CAPTAINNICK
  • 2003 FORD RANGER
  • 6 CYL
  • 4WD
  • 146,000 MILES
I have a 2003 Ford Ranger 4.0. When I turn on the air in any setting except the setting that just enables the middle vents(not feet or defrost), the truck will keep trying to stall. It mostly does it when it is in gear. I have replaced the plugs, wires, and air filter. It is not the A/C clutch because I also tested this with the A/C clutch disabled(I unplugged the A/C). I have also already replaced the sensor that changes the air flow to the engine when you turn the air on or off. A little more info, the mechanic that replaced the plugs did not space them right, so I took them out and re-spaced them. When I started it back up it stopped doing this, but it was miss firing in cylinder 2. So I replaced wires again, and the spark plug in cylinder 2, and the miss fire went away but the car is stalling again.
Saturday, October 23rd, 2010 AT 7:15 PM
  • 109,885 POSTS
Have you checked the compressor? I have seen situations where the clutch is locking up and places enough load on the engine to stall it. Also, was it the idle air control motor that was replaced? Have you had any additional issues with the #2 cylender? Have you checked for vacuum leaks?
Saturday, October 23rd, 2010 AT 9:54 PM
