Stalling randomly
85,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
BRAD WILCOX
In driveway and going down the road but when i got down to 1000 rpm it started right back up as if nothing happened. Sometimes it starts right back up and others it does not. smelled like fuel it finally gave me a check engine light and said MAP sensor and coil. if i replace those will that solve the problem?
Apr 13, 2017 at 4:41 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides. and IAC hole with choke cleaner they get gummy and will cause low speed stalling.
Apr 14, 2017 at 12:34 AM
BRAD WILCOX
I did that and it is still shutting off i replaced the coil and new wires cap and rotor and cleaned the throttle body and sensor im stumped
Apr 21, 2017 at 1:20 PM
HMAC300
  • 48,601 POSTS
chec fuel pressure with a gauge it may be low auto parts rent it. also check wiring harness by back of engine they can wear through and cause that see link for fp.
Apr 21, 2017 at 11:00 PM
