When accelerating from a stop the engine stalls and stutters badly?
178,567 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JUSTBLESSED
  • 49 POSTS
So, I’ve recently put in a transmission in this thing not knowing my A/C condenser has a crack in it causing my transmission fluid to leak and also my Freon, long story short. I also have a misfire in my engine which I can’t quite pinpoint one cylinder misfires then all of them misfire on bank 1 which is 1,3 and 5 cylinders. Fast forward a little when I am stopped at a stop light stop sign etc., and I try to do a take off from start my engine stalls and stutters very badly causing my cabin to shake. Any idea what this issue may be before I start draining money into it?
Oct 9, 2023 at 12:13 AM
  • 55,649 POSTS
The misfires will cause the engine to shake and stall. Can I ask if you have installed new spark plugs? Also, what codes are in the computer?
This guide can help:
If you have installed new spark plugs it sounds like you have a vacuum leak. I would check the intake and throttle body gaskets, use this guide when the engine is cold only:
Also, go over this guide as well:
https://www.2carpros.com/articles/stall-at-idle
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Oct 9, 2023 at 3:26 AM
