So I have some weird stalling issues it will start fine but when I put it in gear it stalls and if you touch anything electronic ( brakes lights etc. ) it stops everything immediately like a short. also, wile running if I tap on or move the driveshaft it stalls. I have replaced the cps, distributor, cap, plugs, wires, rotor, and countless other things. I also have tested it for shorts and could not find anything shorting out or drawing power. it is my daily driver so I really need to figure it out soon. any thoughts or suggestions? Thanks for your time.
Jan 14, 2017 at 6:46 AM
