Stalled while driving and not start
165,300 MILES • 3.2L • V6 • 2WD • AUTOMATIC
CHAD1327
my car was making a clattering noise by the belt and pulleys, when you give it gas the noise would weaken. Check engine light would come on and off. It just stalled while driving and now it will turn over but will not crank.
Dec 22, 2016 at 1:47 AM
  • 55,721 POSTS
Hey CHAD1327
When the engine is cranking over does it sounds normal or does it sound like it is turning over very easy? This is because it sounds like a timing belt or chain that has broken. Can you see if the engine compression? here is a guide to help.
Please let us know happens so it will help others.
Best, Ken
Sep 28, 2020 at 5:54 AM
CHAD1327
When the car is cranking over it sounds very easy i guess.
  • 55,721 POSTS
Yep that's what I thought, see if you can remove the oil fill cap to see if the cams are turning when the engine is being cranks over, you can also watch this video to see if the engine as compression, this test takes no gauge.
https://youtu.be/OhHWUpxdIIo
Best, Ken
