While turning around going up a hill, it shut off and will not start?
180,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
BOGELSER
I was turning around going up a hill and stalled out, car was running great until I stalled and now, I can't get it started. it has a remote starter (which works but I never use) with a rat's nest of wires above the brake pedals that were getting in the way when I shifted. I have replaced both coils and have new plugs and wires and new ICM I haven't put in yet, but it was running great until I stalled it. so, I don't think it's that, I don't know?
Aug 20, 2022 at 8:19 AM
  • 110,248 POSTS
Before replacing things, let's try something. In most cases when this type of thing happens, you either lose spark or fuel to the engine. See if it starts for a couple of seconds using starting fluid. If it does and then stalls, we know its fuel related. If there is no change, then I need you to check for spark to the plugs. Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Aug 20, 2022 at 2:56 PM
