Stabilitrak, check engine light on
55,000 MILES • 2.8L • 4 CYL • TURBO • 4WD • AUTOMATIC
DANDO1020
Usually when going into reverse my stabilitrak light goes off as well as the trailer brake light. Check engine also comes on there is some times a clunk when I put it in reverse from park and well as the brakes kind of having a sticky sound.
Jan 18, 2020 at 9:06 PM
If this only happens in reverse we need to check codes because this could be just a vehicle speed sensor or more serious like a module. Does this happen when going into reverse and you do not move or is it when you start moving?
Let's get the codes in the computer and go from there. If you cannot pull codes, most parts stores can. Just make sure their scan tool can communicate with the ABS module because you may have a code in there due to the stability system.
Jan 19, 2020 at 6:24 AM
