SRS light turned on and headlights started to dim
120,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
TASHA81
I was driving and my SRS light illuminated. After it came on, I noticed my headlights beginning to dim, almost to where it looked like they weren't on but my taillights were okay. It also seemed to drain my battery so low it had to be charged.
Sep 2, 2019 at 10:15 AM
  • 110,248 POSTS
Welcome to 2CarPros.
It sounds like the battery was slowly going dead. What I suggest is to recharge the battery and then load test it. If it passes, then I recommend checking the alternator for output. Here are links that explain how these things are done.:
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Here are links to help with the testing process:
As far as the SRS light coming on, most likely that is the result of a weak battery.
Do this and let me know what you find.
Sep 3, 2019 at 1:30 PM
