Squealing when cold sometimes lessens but starts again
2005 FORD RANGER
60,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
DEBORAH LOBE
I had the serpentine belt replaced in November and the squeal was gone for about a month. Then it returned with a vengeance! It is really loud when I start it then will lessen as I drive. However, sometimes it will suddenly go back to the loud screech. Sometimes when I make a hard turn it will go away for a few minutes. Sometimes it will get louder when I make a turn. I have been told it is probably the water pump. Someone else said it is the harmonic balance. I need help!
Feb 22, 2017 at 6:04 AM
CJ MEDEVAC
  • 11,004 POSTS
Back to throwing a guess at you!
Belt tension-er is lacking strength (replace)
Maybe it is an idler pulley or the one one the tension-er?
What about watching the A/C compressor pulley, is it at a standstill (locked up) while the engine runs?
The 'turning thing' might disqualify any of that above.
Pal standing beside vehicle (NOT IN FRONT!)
Hood is up
Place vehicle in "Drive" while holding the brake
Now do the same for "Reverse"
If the engine torques really hard (Moves a bunch) Maybe your engine/ transmission mounts are deteriorated. If so, maybe a pulley or the belt is scrubbing against something? Can your pal see this possibility?
The Medic
Feb 22, 2017 at 8:18 AM
  • 55,433 POSTS
Yes I agree with the medic it sounds like the tensioner spring is broken or weak. Here is a guide that will show you what you are in for when replacing the belt tensioner.
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
Please let me know what you find out
Best, Ken
Feb 22, 2017 at 10:11 AM
