2002 Ford Ranger Squealing Noise
DAD
i have a 2002 ford ranger xlt. six cyl. auto trans. i asked a question about a week ago about my truck having a loud squealing noise and did receive an answer. i was told it was probably the cam position sensor. my question now is where exactly is the cam position sensor and is it a difficult task to replace . thanks
Jun 7, 2007 at 2:57 PM
INDYUKE
  • 416 POSTS
Before you change the cam position sensor, check simple things first. Your vehicle has a serpintine belt that drives the accessories (water pump, alternator, A/C, power steering etc). They go tend to go bad and "glaze" after a while. I would try popping that off, starting the truck for a few seconds and listen to see if the squealing is still there.
Don't allow the truck to run too long without that belt off though, just a few seconds... long enough to see if the squealing went away. I hope this helps.
Jun 10, 2007 at 4:46 PM
Suggested Repair
Before replacing the camshaft position sensor, remove the serpentine belt and start the engine for only a few seconds to see whether the squeal stops. Do not run it long without the belt. A glazed belt commonly causes accessory squealing.
Conversation Summary
The owner of a 2002 Ford Ranger XLT asked where the camshaft position sensor is and whether replacing it is difficult after being told it might cause a loud squeal. The expert recommended checking the serpentine belt first by removing it and briefly running the engine to see if the noise disappears.
