squeaking noise rigt front side wheel area
165,333 MILES • 2.1L • 4 CYL • AUTOMATIC
CAMONIZ
About 3 months ago i had a squeaking noise on thr front right, on and off, I replace the control arm ,ball joint, wheel aligment, it went away, now its back again same area, could it be a bushings or struts, or my suspscision? not too such of the engine size
Carol
Apr 18, 2014 at 12:11 AM
HMAC300
  • 48,601 POSTS
if anything can be greased try that first ifnot then try shooting some oil around that areathat you think may be squeaking.
Apr 18, 2014 at 3:23 AM
HMAC300
  • 48,601 POSTS
also check wheel bearing and axle shaft unless it only makes it while sitting still
Apr 18, 2014 at 3:24 AM
CAMONIZ
Hi
I am going back to the car shop tomorrow, it does it while I am driving and turn to the right or if the road is uneven,on and off not constant, you see I brought it to honda accord in williamsburg with the same probem he said I needed struts, control arm. upper ball joint, the quote he quoted is they have been repairing my car sine 2007 spent exactly 5515.00 dollars in maintenance work both parties said this car is in excellent shape because I keep up my maintence i$1200.00 honda wanted to do all that work., my son-in law said that too much money and to took it to his repair man said I only needed control arm, ball joint, wheel aligment and cost me $485.00 and the squeaking stop, so kind of confused about this. I dont know if I should stop at honda after work and have him look for this squeak and go see my son'in-laws repair man and see what he thinks it is and the cost of this reapir, he said maybe bushings?
Apr 18, 2014 at 3:49 AM
HMAC300
  • 48,601 POSTS
have the guy that fixed it look at it
Apr 18, 2014 at 3:57 AM
CAMONIZ
ok, thanks for your help.
Carol
Apr 18, 2014 at 3:58 AM
