1998 Honda Accord Front Wheel Squeak
JENNIFER1588
1998 Honda Accord LX, 159K, 2.3L VTec:
My car started making this odd, squeaking noise in the right, front wheel area. I don't know what it is and it's really annoying, especially when I'm driving. It just started out of no where. I brought it to a shop and they didn't know what, what wrong with it either. They told me they replaced my brakes, resurfaced my rotors, cleaned my back brakes, and straigtened out the driver side brake thing. Two days after I picked up my car, the squeaking noise came back, only worse. My friend told me that it could be my shocks. I remember back in early February, I brought it to the shop to get an oil changed because it's too cold for me to do it myself and they told me that one of my calipers was frozen. That wouldn't be a reason, would it? I'm just really freaking out because I don't want my tire or whatever to pop off while I'm driving.
Mar 6, 2007 at 11:55 PM
BRUCE HUNT
  • 3,754 POSTS
You say especially when you are driving. Does that imply that the noise is there even when the vehicle is not moving?
Mar 7, 2007 at 12:26 PM
JENNIFER1588
Yes, the vehicle is still making that squeaking noise when I'm not driving. But, only when you move it or sit on and around that area. It's even worse when I go over tiny little bumps and what not.
Mar 8, 2007 at 3:07 AM
BRUCE HUNT
  • 3,754 POSTS
You need to rule out bearings and look at rubber bushings and mounts. Use of rubber as cushion material is wonderful but as the age takes hold the rubber will where and squeeking will take place. This is probably something that your tire center could address best. This would be someone who specializes in front alignments, etc.
Mar 8, 2007 at 8:02 AM
Suggested Repair
Have a tire and alignment shop rule out the right front wheel bearing and inspect aged rubber bushings and mounts, which can squeak when the suspension moves.
Conversation Summary
A 1998 Honda Accord developed a squeak at the right front wheel that continued after brake service, including new brakes, resurfaced rotors, cleaned rear brakes, and a straightened brake component. The noise occurs when the area is moved or sat on and is worse over small bumps, even when the car is not being driven. A frozen caliper and worn shocks were mentioned as possible causes. The expert advised ruling out wheel bearings and inspecting rubber bushings and mounts, preferably at a shop that specializes in front alignments.
