Squeak from rack and pinion
95,500 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CHEVYRADO
steering wheel has about a half inch play without the tires moving and you can hear a squeak coming form the rack. The steering has been stiffer than normal lately too, power steering fluid is full i just refilled it. is it the rack and pinion or the power steering? pump has not been replaced and truck has 95,000 miles.
Sep 23, 2016 at 2:14 PM
HMAC300
  • 48,601 POSTS
have pump checked for pressure, but may be a rack needs to be replaced.
Sep 24, 2016 at 2:14 AM
CHEVYRADO
Yes pump has pressure pump works fine, I have added a link to the noise. https://youtu.be/9Y3l_GqdU9Y
I think it is the rack.
Sep 24, 2016 at 3:54 AM
HMAC300
  • 48,601 POSTS
sounds more like a clunk than a squeak, but if rest of front end is okay then i would say it is the rack, but have it checked they will tell you and if they do not fix it they normally do not charge for it. it will have to be aligned anyhow after replacement.
Sep 24, 2016 at 6:02 AM
