Sputters backfires
240,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
ROBERTDD
So I have changed, wires, plugs, rotor, cap, MAP, IAC, TPS, ECM, all new electrical under hood, fuel pump and filter because their both one unit, alternator, air temperature sensor, and yet it still sputters when it is cold or hot, but not all the time. It can start up and ruin fit a good four hours and then mess up or mess up right away and then run fine later but the back fire dies cine out of intake. I am stumped. please help, thanks.
Nov 17, 2016 at 11:12 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. check for a vacuum leak then pull valve cover and see if any pushrods are bent/off etc or a rocker worn out or loose. see link.
Nov 18, 2016 at 4:22 AM
