Based on the mileage, consider checking the timing belt and timing.
When there are no fault codes, you need to connect a scanner to look at the data the engine computer sees and is responding to. You will need to know what "normal" is so you can identify what is not right. Also, most scanners have a record feature. This will help in cases like this when a problem only acts up at certain times, like when accelerating, and you cannot be distract by reading the display. You press the "record" button when the sputtering occurs, then it will record a few seconds of data that you can play back slowly, later, and watch what changes. Since the data passes through the scanner's memory, the recording actually starts a few seconds before you pressed the button.
Jan 29, 2018 at 8:41 AM
