I got a 1995 DODGE Neon with the SOHC. It will run fine and then all of a sudden it will sputter and some times die. It does it at any speed and when it idles. I've replaced the valve cover gasket, pluges, fule pump, PCV, oil change, fuel filter and air filter. Still does it. Sometimes the check ingien light comes on and other time not, but doesn't stay on when it does come on. I also tried fule injector and gas cleaners. The car will always start right back up. The car will act up like this a lot and then some times go a day or two with out it acting up. Some times a week or more, but more often now, useually every day. Any ideas?
Aug 1, 2007 at 6:13 PM
