Every once in awhile, maybe once a week (typically during times of frequent engine starting, but not always) the engine takes an extra five or so seconds to start up. It is turning over, but never fully catching. If I stop the process when this happens, it almost always starts like normal. Only once has it not started at all (and then about an hour later it did start). So far I've used a 1/2 can of seafoam fuel treatment, a full can of seafoam motor treatment, replaced the fuel filter, and replaced the air filter. It seems to be slightly less frequent, but its still happening.
Other notes:
It has been over 5 years since the spark plugs and fuel injectors were changed. I would suspect a fuel pump or fuel pump relay, but it is hard to diagnose since it is not a consistent problem. Again I would think that if the fuel pump or relay were bad it would be a more consistent no-start condition. Could it also be something with the timing?
I also have an engine stutter under hard acceleration. The transmission shop said it was the rear differential, and the differential shop said there wasn't anything wrong with the diff. Not sure if it is related, but maybe?
What could be causing this?
Other notes:
Sep 12, 2019 at 3:13 AM
