1999 Ford F-150 Hard to start when engine has been running a
MEVASQUEZ7588
  • 1999 FORD F-150
  • 6 CYL
  • 206,000 MILES
Truck starts fine when cold, hard to start when I drive
a while. I have to turn ac off, step on gas to start
Monday, May 17th, 2010 AT 9:19 AM
  • 109,885 POSTS
Has the check engine light come on? Have you noticed black smoke from the exhaust when it starts for you?
Monday, May 17th, 2010 AT 10:21 AM
MEVASQUEZ7588
No service light on, didn't see smoke but smells like smoke when it starts.
Tuesday, May 18th, 2010 AT 12:11 PM
  • 109,885 POSTS
Have the temp switch checked and replaced if needed. Also, complete a fuel pressure test to see if there is fuel drop off. Basically, when you shut the key, it should hold pressure for awhile. If it drops quickly, you could have a few injectors leaking into the engine and flooding it.
If you need directions, let me know.
Tuesday, May 18th, 2010 AT 1:12 PM
