Engine spits, sputters, and shuts off
2004 NISSAN MAXIMA
150,000 MILES • 3.5L • 5 CYL • TURBO • 2WD • AUTOMATIC
JOWILDER57
just had a new fuel pump put on and it spits, sputters, and then shuts off, but will crank back up.
Feb 11, 2022 at 2:35 AM
Just to confirm, this issue started after the pump was replaced.
If this is the case, then we need to check the pressure when this is happening.
I suspect the replacement pump is faulty. However, we need to start with checking the pressure to confirm this.
Here is a guide that will tell you how to check the pressure:
Please run through this and let me know what questions you have. However, if this is the reason that you replaced the pump and it made no difference, let me know this and we can take a different direction.
Thanks
Feb 12, 2022 at 10:35 AM
