Speedometer will not return to zero?
57,600 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
VIRGOSLIRGO
Just happened today, the tachometer and speedometer gauges won't go to zero, they are stuck at 1 for RPMs and 20 MPH when off, same when idling. Tried disconnecting my battery but no changes. Please help.
Oct 6, 2023 at 4:12 AM
  • 110,248 POSTS
If both are doing the same thing at the same time, it may be the cluster or a module related issue. Have you checked the wiring connection at the cluster? If not, check that first,
If the connector is in good condition, I recommend scanning the can-bus system. CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how it's done:
Let me know if that is something you have done or if you can have it done.
Next, I found an interesting technical service bulletin I would like you to review. I attached it below. I don't work for a GM dealership, so I'm not familiar with the issues. However, the bulletin indicates an updated warranty and policy related to certain electronics. The instrument cluster is on the list.
Take a look through the pics below. It may be worthwhile contacting a GMC dealer to see what they say.
Oct 6, 2023 at 2:26 PM
