Intermittent speedometer
130,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
USEDBYDODGE
The speedometer is analog. It can cut out for seconds but less than a minute.
The brake, traction warning lights also come on intermittently.
A few days after this started the battery drained. Battery is ten months old. I had a 1996 with the same issues.
Could be BCM. But is it just as likely a ground problem?
My left speaker cuts out intermittently. Open driver door and speaker works. So, speaker problem could be a broken wire.
Oct 22, 2017 at 3:12 AM
JIS001
  • 3,412 POSTS
Scan the brace control module for codes. You could have a faulty speed sensor. Post the codes on here so we can see what is going on and try to guide you in the right direction.
Oct 22, 2017 at 7:28 AM
