1996 Dodge Caravan Intermittant speedometer and performance
164,123 MILES • 6 CYL • FWD • AUTOMATIC
TOOPMIKEWI
I have a 1996 Grand Caravan with the 3-speed transmission and a 3.0L engine. Recently the speedometer has been jumping around causing the cruise control to fail,the vehicle may stall at slow speeds and and lurches or "boggs down" in the process. I replaced a coolant temp sensor, purge solenoid, O2 sensor, speed sensor and wiring harness at both a mechanics shop and transmission shop to no avail. Tonight the fuel gauge also failed to work until I arrived home and shut off the van then restarted. My best guess is an engine control module.
May 6, 2009 at 3:06 PM
DOCFIXIT
  • 18,828 POSTS
Hi
During all of this has the check engine light come on?
If yes what codes were present?
Let me know
Thanks for donate
May 7, 2009 at 3:49 AM
TOOPMIKEWI
The error code, which would go off after every repair, gave a code 500 for a speedometer malfunction.
Thanks
May 7, 2009 at 9:36 AM
DOCFIXIT
  • 18,828 POSTS
The VSs you replaced was it on right transaxle output housing? If yes the problem maybe with the output speed sensor located on transaxle below shift lever. Will set Po500 if VSS and output not in sinc.
May 8, 2009 at 8:55 AM
