1996 Dodge Caravan speedometer
230,000 MILES • 6 CYL • 2WD • AUTOMATIC
FEQUET
Dodge Caravan speedometer Problems , it goes crazy up and down , how to fix ? Please !!!
Jun 29, 2010 at 2:29 AM
BMRFIXIT
  • 19,053 POSTS
Most likely its a speed sensor
have to use a scanner and check for codes
drive and check data if speed jumping suspect and replace speed sensors (you have two )
if not suspect cluster pull and check connector to board
Jun 29, 2010 at 4:02 PM
