The speedometer/gear display is not working
83,000 MILES • V8 • AUTOMATIC
FRANKR42
The sides display work but the middle is blank. The car sits for 9 months a year. I only run it in January, February and March in Florida. When I first reconnected the negative on the battery the display worked. The next day it did not. The next day it did again. The next day it went out again and has not returned in the last two weeks. I'm hoping it's a fuse problem. What do you think? If you need a image I can make one.
Thanks, Frank
Jan 8, 2020 at 6:26 AM
94 TRANSAM
  • 680 POSTS
If the other displays are working it isn't a fuse issue as they would all be on the same fuse. It is most likely a bad connection inside that display and will need to be replaced.
Rich
Jan 8, 2020 at 1:46 PM
