My entire speed cluster just up and quit working. The temperature gauge is stuck at normal running temperature, the fuel gauge is stuck at just below 1/2 tank. Then the speed and RPM gauges are none functioning and setting at zero. None of the digital read out on the cluster work. Air conditioner is not lit up or working. None of the interior lights are working. It's like I lost a fuse box some where. I've checked all the fuses, (2 Fuse Boxes) under the hod and found nothing. I just read about the possibility of one being behind the glove box and will check it next. Where else and what else might I check?
Mar 1, 2016 at 11:41 AM
