Sluggish, slow, engine low power
  • 31,937 POSTS
I would be looking for a loose electrical connection with in the ignition system first.
Mark
Tuesday, July 25th, 2017 AT 8:08 PM (Merged)
JTJ
Where can I get electrical diagram for my Peugeot
  • 31,937 POSTS
Our data base does not cover Peugeot as yet so I have nothing to send you, after market work shop manuals are fairly cheap and they will have electrical schematics and fault finding tips as well, this may be a good cheap investment in your car.
Mark (mhpautos)
TUFTY
  • 2001 PEUGEOT 307
  • 4 CYL
  • 71,000 MILES
I have a peugot 307 51 reg. It has slowly been losing power and the engine light has come in but the message keeps changing from cat converter fault to anti pollution fault. I had the cat converter replaced just over a year ago. It's shuttering when I'm in the lower gears and needs a lot of revs to change gears. When I drive up a hill it losing a lot of speed and slows down
DAVE H
  • 13,384 POSTS
Anti pollution filter and cat convertor are basically the same thing. Have the car plugged into a diagnostic computer to read the fault codes and repost with full codes for more assistance
ISSAM
  • 2007 PEUGEOT 307
Engine Performance problem
2007 Peugeot 307 4 cyl Four Wheel Drive Automatic
troulbe code 1152
DAVE H
  • 13,384 POSTS
You have a fault on the H02 sensor somewhere could be the sensor could be the wiring !
BUZZHANS
  • 2005 PEUGEOT 307
  • 4 CYL
  • MANUAL
  • 72,000 MILES
2005 Peugeot 307 4 cyl Two Wheel Drive Manual 72000 miles
Hi, My 307 has the EGE valve disconnected and runs fine, but once its connected it runs very poor. Any suggestions will be highly appreciated. Thank you.
DAVE H
  • 13,384 POSTS
Replace the valve !
