Slipping gears
84,500 MILES • 2.0L • AUTOMATIC
RAF MAPAG
I had slipping gears, my dual clutch was changed and gearbox was rebuilt. But still have slipping gears. The engine revs but car not moving. Also had a message on dashboard transmission limited function. Do you know whats is this? Thanks
Apr 29, 2021 at 11:52 AM
Unfortunately we don' t have a manual on this vehicle as it is not offered here in the USA. However, we do have dual clutch vehicles with similar issues.
If you have a wet clutch then the most likely issue is a fluid pressure issue so the clutch is not actually engaging. .
Here is a video that will help with explaining this transmission in more depth:
https://youtu.be/t8aGgSbtoJE
I would suggest starting with checking fro codes and we can go from there.
Thanks
May 1, 2021 at 1:41 AM
