Signal lights
169,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
JIM.HYATT
My signal lights work fine until i turn on the headlights or park lights, when they are on the signals bleed to the opposite side. No matter which side I select the opposite side flashes lightly too. I replaced the flasher under dash and have checked all of the bulbs, fuses and sockets
Feb 6, 2017 at 12:02 AM
STEVE W.
  • 15,420 POSTS
Sounds like a bad ground at one of the lights. That or a short in the trailer wiring harness or rear light junction block.
Feb 6, 2017 at 2:49 AM
JIM.HYATT
thank you steve, I did find the problem, G112 that battery ground connects to was the problem. repaired the ground and problem solved.
Feb 6, 2017 at 3:18 AM
STEVE W.
  • 15,420 POSTS
Yep, as a man on an old list I frequent was fond of saying "Check the grounds". It is one of the major weak points on today's vehicles.
Feb 6, 2017 at 3:52 AM
