Should I set the timing on a new distributor I installed
2000 CHRYSLER CIRRUS
191,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
JAMIE SHIELDS
  • 28 POSTS
I just installed a new distributor can you set the timing on these kind of distributors? remember the old days you used to be able to set the timing after you put the new distributor in. the car is running great but it seems idling a little fast.
Aug 9, 2019 at 5:25 AM
SCGRANTURISMO
  • 4,897 POSTS
No, there is no adjustment for your vehicle's ignition timing. It is entirely control by your vehicle's Power-train Control Module (PCM) or "computer". In the diagrams down below I have included the factory description of the system for your reference.
Thanks,
Alex
2CarPros
Aug 9, 2019 at 10:44 PM
JAMIE SHIELDS
  • 28 POSTS
Thank you very much once again you guys were great.
Aug 9, 2019 at 10:46 PM
