Should I flush the radiator
250,000 MILES • 4 CYL • 2WD • MANUAL
WHODAT59
Have never flushed radiator. Water rust color. No real engine issues but not having done this I wonder if it would cause too much damage with leaks etc. I can't afford a new truck.
Aug 20, 2020 at 1:35 AM
Good morning,
Yes, I would definitely flush out the system and replace the thermostat as well. Keep flushing it until you get good clear water. Then you can add you coolant to the system..
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Aug 20, 2020 at 1:53 AM
