I'm having issues with shifting will only work in reverse.
Thursday, December 19th, 2024 AT 7:17 AM
KEN L
MASTER CERTIFIED MECHANIC
Can I ask if the gear range lights are all working? Also is the check engine light on? We need more information to help you, please run the codes to see which ones are stored and get back to me so I can get things figured out for you.
Also, does the shifter feel okay like it is moving through the gear okay? Please upload videos in your response of any problems so we can see what to help you with.
SPONSORED LINKS
Thursday, December 19th, 2024 AT 12:31 PM
LEYNA
MEMBER
No codes and gears you can feel when it catches reverse but when going into drive or other slides right through easily but it does seem to work when using manual gear. Every now and then it would catch in drive but takes off really slow trying to check transmission control solenoid which I believe is same thing as a shift solenoid but when looking doesn't seek to have its own solenoid or something no overheating no noises shuddering only time makes loud pop noise is when engaging in manual and when taking off but after that drives okay. Changed fluid not sure how to check if it's converter.
Tuesday, December 31st, 2024 AT 12:57 PM
KEN L
It is hard to understand what is going on, can you please upload a short video? So, the transmission works when left in drive? "Makes loud pop noise is when engaging in manual " this is what I don't understand. Can you please tell explain?
Wednesday, January 1st, 2025 AT 10:21 AM
LEYNA
MEMBER
2016 CHEVROLET SILVERADO
6.0L
V6
4WD
AUTOMATIC
110,000 MILES
Having issues with gear not going into drive only hear seems to work in is fine you can when changed into rev but when going into drive slides right through when I also change and got into manual gear takes a while to get going but does seem to work checked linkage changed trans fluid and not sure how to change the shift control solenoid it's a 6l90 engine made in 8/2016 Chevy Silverado 2500 hd 4wd
Wednesday, January 1st, 2025 AT 10:39 AM
(Merged)
KEN L
Did you run the codes for the system to see if any are stored? Also, when you put the truck in drive does the light for drive illuminate? Here is a guide to help us:
Can I ask why you think shift control solenoid is bad, was there a code? If so, what is it?
SPONSORED LINKS
(Merged)
LEYNA
MEMBER
Okay, so, apparently the linkage was not connected but now it engages in all gears finally perfectly fine but when driving doesn't seem to want to pick up last gear what should I do now.
Sorry for video being hard to see we live on a ranch so we're driving on river rock which makes it so bumpy
Video (Click to make bigger)
Thursday, January 2nd, 2025 AT 8:53 AM
LEYNA
MEMBER
But notice how when shifting rpm goes up where I'm having issues as to why and what to check
Thursday, January 2nd, 2025 AT 8:54 AM
KEN L
Thanks for the video it helps. I can see the RPM's going up. Can I ask if when you did the fluid change did you change the fluid filter? I have seen the filter come loose form the valve body and suck air which can cause this issue.
Thursday, January 2nd, 2025 AT 10:33 AM
LEYNA
MEMBER
Yes put new filter and person that I had come look at it did say it valve body might adjusting if not mistaken he said
SPONSORED LINKS
Thursday, January 2nd, 2025 AT 11:47 AM
LEYNA
MEMBER
Ok now living on ranch and it's all diet road as u can see bumpy too the fact that we havent been able to push on the gas like we would on highway would that make a difference because mechanic did a reprogramming on computer just a thought
Thursday, January 2nd, 2025 AT 11:49 AM
LEYNA
MEMBER
Another question is I'm not sure if theirs sound on video hopefully but can you hear the sqeaking when going over rocks which is everywhere so you can hear it all the time but not sure what bushings they'd would be
Friday, January 3rd, 2025 AT 10:06 AM
KEN L
Yep, I have seen a reflash both fix and make a problem worse so it depends on the program that is loaded. I would clear the codes and take for a drive and then run the codes again, also did you try the hard system reboot?
