My transmission has no reverse can we fix it?
150,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
JOSE M LOPEZ2
My truck when put into reverse gear make loud screatching noise and metal clank
May 1, 2016 at 12:33 AM
HMAC300
  • 48,601 POSTS
check brakes all around it may be the brake squealers making noise.
May 1, 2016 at 1:17 AM
HMAC300
  • 48,601 POSTS
shoot thought it was something else. Have a trans guy check this out sounds like something may be broken in trans.
May 1, 2016 at 1:18 AM
JOSE LOPEZ2
Yeah im taking it today i think the sun shell broke off inside
May 6, 2016 at 10:55 PM
  • 55,612 POSTS
Let us know what you find out so it may help others
May 7, 2016 at 12:38 AM
MYDLITE58
  • 8 POSTS
Lost reverse but still has first. Do I need to replace the transmission?
May 6, 2021 at 5:15 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The transmission will definitely need to be removed and be rebuilt. Having the transmission rebuilt will be a lot less then having a new one installed.Most transmission shops have plenty of your transmissions ready to go (4L60E or the 4L80E) So it can usually be done in an 8 hour day. Hope this helps and thanks for using 2CarPros.
Danny-
MYDLITE58
  • 8 POSTS
Thank you and I totally appreciate you answering my question so quickly.
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks again for using 2CarPros. Please feel free to use us again in the future.
Danny-
BUFORDBOX
Just happened today, cranked truck, put from P into R to back out, briefly engaged and moved about a foot in reverse before I hear a pretty loud noise from underneath. Something either broke... or disconnected. Tran immediately disengaged. I have no reverse ... when I select it I hear a high-pitched whine. Still have full function P and all forward gears.
Will still only crank in P or N. Fluid ok.
Internal? ... or any chance something less major?
Thanks a lot.
May 6, 2021 at 5:16 AM (Merged)
BRIAN 1
  • 1,030 POSTS
the reverse reaction sun shell is stripped,this is a pretty common problem.they have an updated sun shell for these.you have to remove the trans and tear it down,there not to bad to do,I've done a few.post back with any other questions.
