1998 Chevy Silverado Driver's Side Rear Tail/Brake/Reverse
KDOGS
  • 1998 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 137,000 MILES
The driver's side rear tail/brake/reverse lights aren't working, but all of the others work fine. The driver's side front blinker flashes faster than normal, which I'm assuming is telling me something. I replaced all 3 bulbs in the driver's side rear and I also checked/tested all the fuses - all are good. Does anybody have any ideas on what I should try next?
Tuesday, September 28th, 2010 AT 11:28 PM
HMAC300
  • 48,601 POSTS
See if you have a good ground for the lights to work, probably not. It may be the connection that does it. Also clean the ground on the frame rail by the rear bumper.
Thursday, September 30th, 2010 AT 5:54 PM
FARMBOY12008
Also I belive your truck instead of having three individual sockets for the bulbs it has a circuit board for them I had a 98 that did the same thing and I replaced the circuit board and it fixed the problem. Hope this helps
Friday, November 5th, 2010 AT 12:13 PM
