Transmission shifting issue
16,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
JESSESOCAL
When you put car in gear it will take off and sometimes shift to second, but most of the time it will going to like no gear. you can bring up rpm some times and it will go but more than not won't move until turn it off and on again.
Apr 6, 2019 at 12:10 PM
Good evening,
How long since you changed the fluid and filter in the transmission?
Is the check engine light on? It sounds like it is slipping internally.
Apr 6, 2019 at 12:44 PM
