Shifter stuck in park
199,000 MILES • 2.3L • 3 CYL • AUTOMATIC
EVE5013
The car turn on but will not shift from park to reverse.
Apr 13, 2018 at 11:45 PM
good morning.
On the console, there is a slot that you can insert the key to release the interlock if that is what is causing your issue. have you tried this?
also, if it is not the interlock preventing this issue, it may be the cable from the shifter to the transmission that is causing this problem. the cable seizes up inside the casing not allowing movement of the shifter to select any gears.
Do the brake lights work?
Apr 14, 2018 at 12:06 AM
EVE5013
I have not try anything yet, the brake lights do work. Thanks for your help.
Apr 14, 2018 at 12:41 AM
okay, good. try releasing the interlock with the key in the slot and let me know.
Apr 14, 2018 at 4:18 AM
