Severe backfiring
150,000 MILES • 7.5L • V8 • 2WD • AUTOMATIC
HVYTRK
A friend has an 81 E series camper van with a 460. Has an air injection pump. It it backfiring severely through the muffler enough to have swelled the muffler and popped several spot welds. It looks dangerously close to a full rupture. Does this while decelerating. Muffler and plugs, wires, cap and rotor tune up done October along with winterizing. About 4,000 miles back had head gaskets replaced along with heads re-surfaced and carbon cleaning, etc. RV has been driven possibly 300 or less miles on three short trips to see this muffler nearly exploded. Engine smells as though running very rich. Does this sound like a carburetor loading problem or possibly that gulp valve? Thank you
Correct mileage is 88,425
Jul 14, 2018 at 2:42 PM
  • 55,746 POSTS
Yes, when the gulp valve fails the van will backfire. Here is a guide and diagrams to help you see if that is the problem:
https://www.2carpros.com/articles/engine-backfires-while-running
Please run some tests and get back to us.
Cheers, Ken
Jul 16, 2018 at 5:29 AM
