1981 Ford E-Series Van mpg
1981 FORD E-SERIES VAN
ROCKNROLL4267
Engine Performance problem
1981 Ford E-Series Van V8 Two Wheel Drive Automatic 200k miles
what can I do to or buy fot the engine to improve mpg
Jan 16, 2010 at 5:00 AM
HMAC300
  • 48,601 POSTS
it is hard to make a box(van) get gas mileage. Other than keeping it in tune and maybe a gear change not much. these usually fall into the 12-15mpg range and not much else can be done with them. At least one as old as yours.
Jan 24, 2010 at 12:40 PM
HIPPO800
  • 29 POSTS
The best ideas would be interchange the old heads for pedestal rocker heads; @ 85 heads(v-8), or head (300-6). Bronze guides superior ro cast iron.
The engine compression should be @ 200 psi, and switch to a dist cap with brass contacts. Low resistance plug wires and an MSD blaster SS coil.
Use Lucas oil treatment and a good synthetic 10/30.
Good mileage requires precise valve geometry and precise preload. Vacuum reading in prk should be @ 22in./hg, warm engine.
Feb 3, 2010 at 11:53 AM
