Service engine soon light
MJOINAL
  • 1993 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • MANUAL
  • 71,000 MILES
I have a Chevy S10 (1993) truck. When I start the truck in the morning it is perfect. But after driving 10-15 minutes the "service engine soon" light comes on and the vehicle starts to stall. I took the vehicle several times to the local mechanic, but it seems that they cannot understand the problem. First time they replaced the distribution cap and rotor button, then they changed the engine coolant, temperature sensor and temperature sending switch (they thought vehicle control module was not getting correct engine temp). After all these work DTC 15 was found by another workshop (as the first workshop did not have proper scanner to read the error code) and suggested to check the circuit for sensor. When I told this to the previous workshop they told me that they already worked on the sensor circuit.
Sunday, March 20th, 2016 AT 1:21 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,323 POSTS
Yep that year car is an obd1 vehicle which the codes are gathered by using this method
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
You can see that 15 is the coolant sensor circuit, since they already replaced the sensor it must be a wiring problem or an ECM that is bad.
Please let me know what you find.
Sunday, March 20th, 2016 AT 2:07 AM
