2000 Chevy S-10 check engine light
SOSB2
  • 2000 CHEVROLET S-10
  • 4 CYL
  • 161,552 MILES
How to get check engine light to go off
Thursday, February 18th, 2010 AT 12:49 PM
JDL
  • 16,098 POSTS
Hi, one way, might be to fix whatever is wrong. Use a scanner and erase codes. Sometimes taking the battery cable loose for a while might cause a reset, If you do it that way, might cause other issues?
Thursday, February 18th, 2010 AT 1:33 PM
SOSB2
I'll give it shot, by scanner, you mean a code reader, right.
Thursday, February 18th, 2010 AT 2:23 PM
JDL
  • 16,098 POSTS
To me a scanner will not only check codes, but, show live engine data. The code reader will only read codes, it is possible, the reader might erase codes, not sure? Your local autostore might erase codes for you, free of charge.
Thursday, February 18th, 2010 AT 3:02 PM
