Service engine light on
170,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JOHN GLASS
  • 53 POSTS
I have recently bought the car listed above 2.0 SOHC. I had a friend and a fella at local parts house put on computer.Both said timing belt skipped 1 tooth and the Idle Air Control Value. We reset the light but it come right back on.The car runs great, my opinion don't think it has skipped a tooth, just runs to good. So should i tear down and replace belt an tensioner? An get new IAC valve? or maybe clean mine? An I love 2CarPros been looking on here for about 3 years now to get advice. thanks and this my first question to post. Thanks for all the help.
Nov 30, 2019 at 10:55 PM
Good morning,
Remember, parts guys sell parts and are not technicians.
Let us start with the codes? Can you post them so I can check on the possibilities?
Nov 30, 2019 at 11:02 PM
JOHN GLASS
  • 53 POSTS
Yes sir, I would second thought. And be honest I can't remember the codes. but I can do the key back an forth three times an count the service light as it blinks? Will that work??
Nov 30, 2019 at 11:10 PM
Yes, that would be great.
Nov 30, 2019 at 11:21 PM
JOHN GLASS
  • 53 POSTS
32,54.
Dec 1, 2019 at 12:22 AM
Okay, the 32 is for the EGR circuit. This may be a wiring issue.
The 54 is for cam sensor.
I attached the flow charts. Most of the time it is wiring that is the issues especially due to the age of the car.
Glad you did not listen to the parts guy.
Dec 1, 2019 at 12:46 AM
JOHN GLASS
  • 53 POSTS
Thank you. it runs fine though.i recently had problem. it kept blowing fuel pump fuse. I read a few post on 2CarPros and believe it was ASD relay going bad?? I swapped fuel pump first,same thing.It would crank an idle. then 10 minutes or so blows fuse. After that an little more reading I swapped relays.I have not blown a fuse but no my blower motor won't come on??I check fuses any idea on the?? And again thank you I been needing you guys.
Dec 1, 2019 at 1:06 AM
The relay you removed and placed somewhere else may be the failure. Did you replace the relay with a new one?
Dec 1, 2019 at 1:14 AM
JOHN GLASS
  • 53 POSTS
I didn't,,but the one I pulled out is still out. Did I mention I got a 1997 neon as well? it was running and just quit.Then I bought the 1995.
Dec 1, 2019 at 1:39 AM
I attached a wiring diagram of the blower motor system. Check the fuse for power on both sides.
check for voltage to the motor .
Dec 1, 2019 at 1:55 AM
JOHN GLASS
  • 53 POSTS
bad contact in fuse panel. thank you
Dec 1, 2019 at 4:13 AM
Good find.
You are welcome.
Dec 1, 2019 at 4:25 AM
JOHN GLASS
  • 53 POSTS
I had a new coil for a 1997 Dodge Neon, so I sorta put it on the 1995 Neon.I swapped plugs as well. could that be some of my wiring issue?
Dec 1, 2019 at 8:18 AM
JOHN GLASS
  • 53 POSTS
meaning the plug that matches the coil pack. sorry about that.
No. They are the same coil.
Dec 1, 2019 at 8:21 AM
JOHN GLASS
  • 53 POSTS
thank ya sir.
Dec 1, 2019 at 10:07 AM
You are welcome.
Always glad to help.
Dec 1, 2019 at 10:39 AM
JOHN GLASS
  • 53 POSTS
I got 2002 Chevrolet Blazer 4x4.I was wondering if I could change from push button 4 wheel shift to a manuel shift?
Dec 3, 2019 at 9:55 AM
We are off on a new vehicle.
Site rules are one vehicle per question.
Please go back to the beginning and start a new question with your issue.
Dec 3, 2019 at 9:58 AM
JOHN GLASS
  • 53 POSTS
sorry about that but I have recently run into problem with the car.When I start it,,the idle is ruff and will barely rev.I have sorta wiggled the wires going to coil pack and it will pick up, but more you wiggle it get just about kill it.When idling I pull the plug loose then went to EGR an it bout went dead so I put it back real quick. My question is, should I start unraveling the tape on harness an look for loose connections?thanks again for your help.
Dec 4, 2019 at 4:59 AM
Yes, I would. You have an issue with the harness or the connector itself.
You are welcome
Dec 4, 2019 at 5:01 AM
JOHN GLASS
  • 53 POSTS
yes I was thinkin connector myself cause if u push in on connector it will get worse,but good thing is the harness isn't all jacked up its actually in real good shape.So unplugging EGR an it doin thing was a good sign??
Dec 4, 2019 at 5:30 AM
I would replace the connector. They make what is called a pigtail at a parts store. Tell him your vehicle information and ask them for a pigtail. Then you just solder and shrink wrap the wires.
Dec 4, 2019 at 5:33 AM
JOHN GLASS
  • 53 POSTS
believe I got that straight. the connectors seemed loose inside connector. I been driving for about 20 minutes and when I shut it off I heard a humming sound that seemed to be coming from that box that is located on top of driver side fender.Does that mean computer trying to go bad??
Dec 4, 2019 at 10:49 AM
Can you post a picture of the box?
Dec 4, 2019 at 10:51 AM
JOHN GLASS
  • 53 POSTS
did you ever get my picture? I will send again.
Dec 4, 2019 at 8:12 PM
Unplug it after turning it off. If the noise stops, then yes, replace it.
Dec 4, 2019 at 10:54 PM
JOHN GLASS
  • 53 POSTS
I have recently started hearing a noise sounds like it coming from transmission. On a cold start if you put foot on brake an hold the sound starts, you put in neutral an it stops.It won't do it every time but was just wondering what it may be?? An another if defrost is on why are the fans kicking on an off?? Relay again??Thank you
Dec 11, 2019 at 9:27 PM
As far as the transmission, I would start by changing the fluid and filter. It may be making the noise from a clogged filter.
As far as the defrost, The AC compressor is commanded on in defrost which means the cooling fan will operate.
Dec 11, 2019 at 10:47 PM
JOHN GLASS
  • 53 POSTS
yes it does, but the fans will kick on an off. is that what they are suppose to do? And that noise on transmission is like clack,clack, clack. put in neutral and it's a hard shift. could it be over filled?
Dec 12, 2019 at 5:21 AM
JOHN GLASS
  • 53 POSTS
thanks again Roy for the advice.
Dec 12, 2019 at 5:22 AM
Yes, the cooling fans are normal.
No to overfilling.
Can you upload a video of the noise?
Dec 12, 2019 at 5:28 AM
JOHN GLASS
  • 53 POSTS
yes sir I can jus give me few mins please,,and thank. ya roy. makin me feel better everyday
Dec 12, 2019 at 8:35 AM
No problem.
Dec 12, 2019 at 8:37 AM
JOHN GLASS
  • 53 POSTS
hopefully you get this.
Dec 13, 2019 at 3:48 AM
Okay, I heard the noise, That is way too deep for a transmission noise. It sounds more like engine related.
The first thought is a cracked flywheel. I would have a shop double-check this and confirm. It could be a warning of something serious coming up.
Dec 13, 2019 at 3:57 AM
JOHN GLASS
  • 53 POSTS
tht video prolly made it sound lil worse than I think it actually is..Can I send u video of an overall basic of car??Like I tell u everything I kno about car in video??
Dec 13, 2019 at 5:21 AM
I just need to hear the noise. Maybe one with better sound would help.
Dec 13, 2019 at 5:32 AM
JOHN GLASS
  • 53 POSTS
the noise is not getting louder but I did seem to catch in action.Car was on operating temperature, and when given very little gas. it sounded like it was low of oil but wasn't knocking.
Dec 15, 2019 at 10:49 AM
I still need to hear the noise .
Dec 15, 2019 at 4:05 PM
JOHN GLASS
  • 53 POSTS
Recently I've noticed my windows fogging up from inside. more than likely that is heater core leaking right?? And i have noticed like the rpm's will hang little high when foot off accelerator or when driving. When I ease my foot off it the rpm's will drop,but soon as foot back on gas it jumps back up there like very sensitive?? Could the be signs of weak fuel pump??
Dec 18, 2019 at 11:32 PM
