2011 Dodge Caliber Serpentine Belt
You can safely remove that mount and change the belt. Use a jack with a wood block under the engine to support it then remove the mount. I'll post the belt change info and diagram below
1. Using a wrench, rotate accessory drive belt tensioner (8) counterclockwise until accessory drive belt (2) can be
removed from pulleys (5 and 9).
2. Remove accessory drive belt (2).
Suggested Repair
Support the engine with a jack and a wood block, then the motor mount can be removed for belt access. Release the serpentine belt by rotating the accessory drive belt tensioner counterclockwise with a wrench. If the tensioner will not move and its pulley is unusually stiff, do not force it; have a shop inspect the seized tensioner.
Conversation Summary
The owner of a 2011 Dodge Caliber 2.0 with A/C asked whether the motor mount could be removed to replace the serpentine belt and requested a routing diagram. The expert said the mount can be removed safely after supporting the engine with a jack and wood block, and described rotating the tensioner counterclockwise to remove the belt. The owner later reported that the tensioner would not move in either direction and its pulley was stiff, so they planned to coast the car to a nearby garage. The expert acknowledged the stuck tensioner and wished them well.
