Will not start, security light, how to reset the computer and or ignition?
100,000 MILES • 3.4L • 6 CYL • 4WD
JASON49272
Will not start and light does not flash. How do I reset the computer and or ignition?
Dec 11, 2018 at 9:00 AM
STEVE W.
  • 15,367 POSTS
If you turn the key on do you see the security light come on, then go off? If yes, what happens when you turn the key? Does the engine turn over like it normally does but does not start? Or does it do nothing, or maybe just a loud click or thunk?
This guide can help us fix it:
https://www.2carpros.com/articles/how-to-reset-a-security-system
If it turns over okay but is not starting, I would take a look at the crankshaft position sensor and its wiring. They can fail and not set any codes.
Jan 29, 2021 at 3:19 AM
