White smoke on acceleration
126,000 MILES • 1.6L • 2WD • MANUAL
HUSAINTAI
Car listed above (petrol) is giving white smoke on acceleration. engine not overheating neither is coolant leaking. what could be the issue?
Apr 13, 2019 at 6:28 AM
  • 110,248 POSTS
Welcome to 2CarPros.
In most cases, white smoke is an indicator that engine coolant is leaking into the combustion chamber. The coolant burns with the fuel and produces a white smoke. Take a look at this link:
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
Now, I don't want to concern you with the above link. If you live in an area where the temps are cooler, it could simply be condensation burning off in the exhaust. However, that should stop as the engine warms.
If you are concerned that it is a head gasket, here is a link that shows how to check for a bad head gasket. Just follow the directions.
Do that and let me know what you find.
Apr 13, 2019 at 11:43 AM
