2000 Saturn SL2 iDLES too fast
2000 SATURN SL2
158,000 MILES • 4 CYL • FWD • AUTOMATIC
GOOGLES70
The vehicle will Idle at 1200 RPM in park, It will jump to 2000 rpm when you put it in gear then settle back to 1200 rpm.
It does not show any trouble codes!
Sep 20, 2009 at 2:14 AM
SATURNTECH9
  • 30,869 POSTS
could be ur iac motor try letting it idle in park while its idling high and use a little hammer and tap gentle on the iac motor and see if the idle comes done if it does then it needs a new iac motor let me know how it goes.also if u have a car with air injection then the hose that is by the power steering pump could have come off let me know.
louie
Oct 2, 2009 at 1:11 PM
