1993 Saturn SL2 rpm go crasy
93,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROLLAND BRUNET
HALLO
WHEN MY CAR IT'S ON THE ROAD RUNNING AFTER A GOOD TIME (20 MINUTES) IT RUN TO 70 TO 80 KHS AND SODENLY THR RPM INDICATOR JUMP FROM
2000 TO 3500 AND WE CAN EAR THE MOTOR SOUND GO HIGH REVOLUTION AND THE CHECK ENGIN LIGHT GO ON .
IF I SHOT DOWN THE ENGIN AND START BACK IT GO OK BUT IT START BACK IN FEW MINUTE
IT DO LIKE WHEN THE CAR IT ON PARK AND YOU PRESS ON GAZ PEDDLE BUT WHEN IT DO THAT THE CAR IT MOVING IF I PRESS ON GAZ IT MOUVED
NORMALY BUT THE RPM INDICATOR GO WILE
THANK YOU IF YOU FIND A SOLUTION.
May 13, 2010 at 3:24 PM
PLUS2COM
  • 27 POSTS
Im not sure im really getting what your saying .. does the gauge just act up or does the motor race as well .. this sounds to me like a fault in the EGR valve have you read the codes from the check engine light more information would be helpful as well , same with spell check .. hope to hear from you soon
May 21, 2010 at 3:54 AM
