I think I have overfilled my ac. I first added a full can of R134A and the system performed well, but seemed like it could've used more. So I took a second can and commenced to add it, after about half a can it stopped....as if it was full. I followed the directions, car running with ac on while I was filling it. Now the problem is, the inside fan runs but NO cold air. My thought process is that I probably overfilled it and there is a fault switch that automatically cuts the system off when it has TOO much freon. How can I bleed off some of the freon and reset the system so that it will work?
Thank you in advance
Jun 29, 2010 at 12:48 AM
