[quote:dace5112d2="malco"]on a flow chart (from GM for no spark code) that I have it says to check circuit 451 to B+ found 451 at connector. for B+ I had no idea what that was so I checked it as battery positive is this correct? I am thinking there is a short or open in the wiring somewhere. This car was recently purchased by sons girlfriends mom so have no history on this car.
What are the different paths the codes send you to?
Also on the rear of the engine between the heads there is a sensor with 2 wires someone wired it in kind of cheesy was wondering if this car could have a camshaft sensor?
Thanks for listening[/quote:dace5112d2]
i sent u the info i said i would.when u see the wiring diagram u will be able to figure out what is power and ground.there is now cam sensor in ur car.what color wires are going to that sensor with the cheesey wiring?
Jan 30, 2010 at 11:59 AM
